Baer brakes, Global West control arms, chassis braces
olds443
Updating my T Type so this is all up for grabs.
1) Global West Negative Roll upper control arms $300 obo plus shipping
2) Baer Brakes 13" rotors on modified B Body spindles $150 plus shipping obo
Rotors were turned not long ago machinist said they are near min thickness but good to go.
3) factory chassis / frame braces (Grand Prix and F41) $75 plus shipping
4) Hollow F Body sway bar $80 plus shipping (includes barely used poly end links)
5) Springs are Hotchkiss that were cut before I got them, honestly they were probably too low as my car was almost on the bumpstops. I think they were originally for an F body. It rode good though. Free just pay shipping.
6) Bilstein shocks $25 pair plus shipping
7) lower control arms $25 plus shipping
Where are you located and what does negative roll mean on the Global West Uppers?
Thx.
Thx.
I'm in Northern CA about midway between SF and Sacramento.
Negative Roll is there term. basically the arms add alot of camber and help plant your tires when turning. I autocrossed on rebuilt stock arms with the same springs and then these arms and it was a huge difference
I would like the lower control arms pending some details... How are bushings and ball joints? Recently replaced / need replaced? My zip is 45431 to figure shipping.
Do you have any pictures of the upper control arms from a better angle?
Bushings are great, ball joints seemed fine on the car (no play, etc) however I feel they are a lil worn and would replace them while they are off.
Will the baers work for stock gbody spindles?
They are sold but the kit was made to work with B Body spindles. If you could modify the bracket (easy to do I would think) then I'm sure this could be made to work on G body spindles. This came out before all the new super arm options for g spindles
Again the spindles are sold btw
Looks like $70 to ship fed ex.
