Bearing Clearance on a 10.30 motor?
Chris McDade
Building a new motor for the GN right now. What bearing clearances do you recommend? It will half track/Street car. It will be a mid to low 10 car.
109
.030 Weico pistons
RJC girdle
214/214 flat Tappet
Iron Heads and intake fully ported.
66 S trim turbo
9" art Carr 3200 Stall.
Thanks in advance
There are lots of differing opinions on bearing clearances.
I have had very good success with .0017-.0021 on the rods and .0020-.0025 on the mains.
As long as you have very round, close toleranced main and rod journals you can get away with tighter clearances. Poor tolerances (out of round and/or tapered) journals will have problems with tighter bearing clearances.
Obviously, tighter bearing clearances will provide better oil pressure.
Dave
.018-.020 mains and .020-.22 rods. You will overpower your converter before you can maximize the use of the other parts in your combo.
