87buickracer
- Dec 2, 2004
What's the most clearance anyone has ran on their main bearings with high volume oil pump?Also rod bearings,thanks in advance for any input.
.0025 would be a max but i wouldnt recommend it, i also dont care for the high vol. pump im switching back to a std. vol. .0020 is a good safe clearance for the rods & mains on the turbo 6
Just make sure the oil is hot before pounding it. I wiped out the front of my block (cam thrust form excessive load). Probably was a little too tight. If you have a billet roller with a torrington thrust bearing i wouldnt worry at all. I would worry about bursting the oil filter if the engine oil is not hot enough though and you have a high volume pump. I still wouldnt go with over .002in if you are running the standard oiling setup in the stock block.I'm thinking of putting high volume pump on my engine as well.Looking for maximum oil pressure.
That was the gallery plug after the front cam bearing, right? Also says how restrictive that passage must be.About the warm oil thing:
Of course it is important to warm up the engine before hitting it but if anybody doubts what cold oil is like get this...
Even with one oil galley plug out, my cold oil pressure was about what it was with the plug in place - about 65 PSI. After about five minutes it would fall to about 15 PSI, and after 15 minutes - hot it was about 8 - 9 PSI and would not climb much past 20PSI.
Amazing how much pressure cold oil will build.
