I would love to do some back to back testing from pump to e85. I don't see you picking up 10 percent In just a fuel change with everything else being equal. If that is true that's awesome.
You picked up 13mph, by opening the dump?
Never said you did, just learning here.
Can you post some dyno charts, mod lists, and data for any of those 50 plus cars. Would like to see what they were running before and after etc
Mod list doesn't make a difference, just was going to look at power made, torque made, boost levels, rpm, etc, just looking at data.
I'm not saying your wrong or right I'm just looking for data to further support this theory
How much power does that car makeCorrect .. 13 mph ... THRU ATR EXHAUST VS OPEN DUMP ... that was @ 25 psi on A 60-1
That's just it ... it isn't a theory ... I could care less if you believe or not ... to me makes no difference at all
I was just stating what the OP posted is relatively consistent with what I've seen.
My point to my post was .. if you don't optimize the E85 Tune.. WTF is the point ?
your handicapping what the fuel is capable of ... so whats the relevance in a before and after ALL ELSE being equal ? E85 isn't like a standard fuel so why would you tune it like one.
The fuel itself will increase power.. but when the setup is optimized for E85 it will far out perform a setup like the OP had.
Can you post up a dyno chart of a E85 conversion that the power was the same ? "ALL BEING EQUAL "
Damn dude relax, I'm not trying to pick a fight or say you're right or you're wrong. I'm just trying to learn and collect data and learn from it and hope others can learn from it as well.
As for switching to E85, it's a great thing for sure and you should tune to it potential, however I can see people switching to get the same performance from it at half the cost of race fuel.
Sweet, might have to do some testing. Figured my dual atr 2.5 was free flowing enough. I'll play around with that
the torque did raise....however, the dyno guy said his tach signal was off on his end during both the 100 octane pulls....so the torque values were off. (what he said anyway)I have always heard of the torque going up..Did it?
Did you notice an increase of spool up like most have noticed?
