Belltech springs issue
1000MileStylez
Black Sheep
So i have belltech springs which drop the rear by 1.5". I have the QA1 single adjustable shocks in the rear but the rear drops too low when the car is raised and they fall out of the perch. Should i get different shocks? If you have a Qa1 part number too that would be help! I was also thinking of travel limiters.
You'll either need to put limiting straps on the rear or change springs. If you want different shocks then you'll need to go through the part books to find the OAL, rate, configuration, ect.
Heres a little update for anyone who encounters this issue. I made these at work but you can buy them at TRZ motorsports. Can fully lift the car off and the springs have tension.
