- May 28, 2001
Timing is at 32 at 3000rpm which is were it begins to spool and it tapers down to 30 at 3500 about 10psi. Wot timing is 21 at 30psi.
You are giving away HP on the top end with only 21 degrees of timing.
As long as you are running 116 octane race gas and I assume you are with that monster of a turbo you should be able to run 25 degrees
