usetaboost
SAY CAR RAMROD!!
- May 4, 2005
What's worth doing and what's not? Don't plan on going any faster than high 10.
SignUp Now!I posted about this b4. Stock valves, a good valve job, and about an hour or grinding and a few sandpaper rolls will net 90% of the gain. Big valves dont do dick. Neither does porting for your goals.
He posts no goals that I see??
I did a little searching before posting this. Didn't see much but some home porting threads which looked like a waste of time. Thanks for posting Bison, much appreciated and I welcome any more suggestions.I posted about this b4. Stock valves, a good valve job, and about an hour or grinding and a few sandpaper rolls will net 90% of the gain. Big valves dont do dick. Neither does porting for your goals.
What if you had a choice between two different set of heads, same price. Which would you choose:
Set 1:
3 angle valve job
Stock valves
New seals
Guides cut
Comp 980 springs installed
unported
Set 2:
5 angle valve job
Large Stainless valves
unported
new seals
guides cut
100# Chevy springs
Some tech advise is better than none:biggrin:He posts no goals that I see??
Why in your sig does it say: NO MORE TECH ADVISE. Please do not contact me unless you have a response to parts for sale
Yet you are in tech??
Bison, will the bang be worth the buck or put the money and time spent on it elsewhere?
First off, porting a cast iron cylinder head is a DIRTY, DIRTY job. You will NEED a good electric die grinder of high quality. Makita makes an affordable one that works great. You need to get a motor controller, or wire in a dimmer switch to control the RPM of the grinder. A few carbide burrs in 6" shank (4" minimum) I usually cut the shanks down on my double cut burrs to 4"-5" to help control wobble. Eye protection, and a dust mask and a vacuum running all time to help control dust.
Have a valve job done with a good three angles on the seat. Then dyekem the valveseats and lap the valves for a good visual of the lower angle. Open the valve bowls up while leaving a .125" wide lower angle remaining. On the intake, shorten the valve guide about .30" and shape the leading edge of the guide into an airfoil. Radius the back side of the guide on the biased side (the widest area along side the guide) into a good radius, as the air wants to go around the back side of the guide, so let it. Straighten the port walls and open the inlet of the port to match the gasket. Open the port up all the way at the pushrod pinch. (stock intake gasket, NOT 1200 FelPro) widen the port floor on the short side radius, but do NOT completely remove the hump in the short side corner, just put a nice radius on it, and continue with a nice radius into the valve seat. Raise the intake port roof about .125", too. Grind out the head bolt bulge on the port wall, and clean up all the lums and bumps in the port. Polishing the intake port does nothing for flow, but it does show you where you have low/high spots. This will net you about 85-90% off what an intake is capable with out moving valve centerlines.
The exhaust: Completely remove the valve guide in the port bowl, put a good radius on the short side while widening it about .125" on both sides. Straighten the port walls, and polish. Maintain a .125" valve seat lower angle, too. You can open the bowl up wider under the seat, but be careful, as there is water real close on the inboard side of the bowl, and it is CLOSE on some heads. (ask me how I know.)
The combustion chamber: Polish the lumps and bumps out of it, and smooth to the exhausr valvel seat. Be REAL carefull so you don't kill the valve job. Some guys put a junk valve in place so as not to touch the seat, but I find the valve gets in the way and just use good tool control. (i.e. strong hands and forearms) Mark out the diameter of the head gsket fire ring (use a old head gasket, because it is already pre-flattened.) Unshroud the vlaves as much as possible, but don't go past your scribe marks or you will have to use a larger head gasket. (felpro 1026 for example, or Cometics)
Grind the side of the rocker pedistals so you can install roller rockers, too.
Hope this is what you are looking for. BUT.....if you have to buy the tooling, it will cost you about the same as buying a real nice head from someone.
REad ALOT about flow dynamics prior to starting, too. speedtalk.com is a good source for reading for HOURS.
Good luck, and after you are finished with just one head, you will find out why they cost so much.:biggrin:
