Steve Wood
- Jul 18, 2001
The truth is that for 95% of those that own a front mount, it makes no difference as we probably don't run fast enough to need a front mount so any front mount will perform the same.
If you don't own a front mount and you insist that you must have one because A) you don't believe the experience and tests of others, and you don't run faster than 10.5s, buy the cheapest one you can find: B) You run faster than 10.5, then buy a CAS if you are buying a new one because you might as well buy the best technology for not much difference in price OR buy a used version of almost anyoness if the price is 50% of the new one or better. Once you hit the low 9s, then you may want to go with the CAS for the technology again.
For the other 95% of us that don't run faster than 10.5, buy a V4, not the v4r, and avoid the potential of heating problems, and have faster spool to boot plus not have to worry about crushing those pipes on steep drives. Better all the way around and you will have fun outrunning most of those guys that have street cars with front mounts...(probably including me
