Best Spark Plug to Run???
Wow, thanks for the great response.... Looks like I will try the NGK's....New to the TR world.... Kirban listed those new e-3 plugs so i figured I'd check what really worked before just buying them...
I have tried alot of plugs in the past in my SBC.. bosch, ac, rapidfire, autolight, champion, splitfire...rapidfires worked the best for me w/ a 6al...
Thanks ALL!!!!:) :) :) :)
Autolite 23's for me. I used to run UR5's but after the porcelain broke off the #1 plug and took out the piston, exhaust valve, and turbine wheel. The tune was safe too. No one I talked to could explain what happened.
i just installed the E3's from Kirban. Dont have to set them and the GN feels even smoother.
very pleased $32.00 plus shipp.
Is it okay to run the UR5 in stock iron heads. When comparing autolite 24 delco CR43TS and UR5 the threads are the same but the shaft is longer
