................ I want this car to be a driver but I want to be able to hook as well. Maybe some drag radials but what else do you recommend?
Setting up suspension is much like your engine performance, it is all about "tuning", the right combination of parts, and the important item which is your budget, and of course your goal of how the car will be used.
There is no "magic" item, but many of them working together will give you the desired results.
Again, like engine performance, the list of items is long. Sure tires, springs and shocks are always at the top, but items like torque converter and frame mods are not initially considered in this mix of parts, as there also other parts that contribute to handling and traction like brakes.
Since many of us have been "messing around" with these turbo cars for 25 years, there is someone that has accomplished what performance level you want to achieve, so when you define that properly, find that person to follow his path which will save you much time and $$$!
