Best way to remove old sound deadener from roof?
TR Custom Parts
Mark Hueffman - Owner
Putting in my 3rd or 4th headliner in my GN in the last 4 years! ( I have lost count at this point! ) Want to remove the old sound deadener on the roof and install dynamat instead. Best way of removing it? The material keeps coming off the ABS board like they didn't use enough glue or maybe it was rolled and packaged right after being glued. At least I was getting a free one every year but sick of doing the job, got better things to do.
This time time I got the bare ABS board and had my local auto upholstery shop to glue on the fabric. This last year the car did not see much daylight as getting divorced, lousy weather, death of a good friend and getting married again took up a lot of my spare time. The GN was locked up in a climate controlled garage so don't think weather had anything to do with the failure of the fabric. Anyway, back to the subject, best way to remove the old deadener panels?
I used a wire hand brush used for cleaning parts. Comes out really well.
Sound deadener removal = hair dryer + plastic putty knife. I sprayed some black Rustoleum up there last time I had the headliner down. There were a few bare spots oddly.
How much room there is between the roof and headliner? I mean how thick sound deadener material I could use, is 6mm too much?
Take the headliner off, measure what they have on there, & go from there.
To me almost 1/4" thick is very thick. You use what works for you though.
The original, now removed, is about 2 mm only. I want to use thicker there. Chuck Leeper, is that 4 mm material suitable exactly for GN T-top?
The choice is up to you & what you’re looking to achieve.
" Chuck Leeper, is that 4 mm material suitable exactly for GN T-top?"
Won't make a difference. Has to be trimmed to fit anyway.
Try to undestand me. So I am working the first time with the gn t-top roof. That is the reason asking the good instructions for the sound deadener material on the roof.
So, what you mean the trimming work regarding the new 2 mm or 4 mm material, or what? How I should trim the material(2mm or 4 mm) before the head liner installation?
The sound deadener issue for the roof of GN is ok at the moment. I would ask now about the elect wires coming from front to the back passanger lamps. The wires has originally taped on to headliner, seemed so when pulled out the headliner. Is it ok to tape or glue the wires on to the roof or let them only lay on the headliner?
How you have done this when you have put new fabrics on to headliner base or renewed the whole thing?
The car is T- top GN
