Scott Atk
Senior Member
- May 25, 2001
The new Innovate MTX from Full Throttle works great, totally self contained with an analog out for PowerLogger. Under $200 too.
SignUp Now!i have an lc1 i have it logging off the scanmaster thru the powerlogger, works great with TT wideband chip you can tune your car to w.e parameter you want on WOT you can set a target A/F and have the computer sort it all out for you by w.e the wiedband feeds it, im actually running a used o2 sensor that was used for about a year or 2 and im having no issues with it i like the lc1 ive had the aem in an rx7 i like aem also but i prefer the lc1 thru scanmaster..the problem most people have with the innovative (lc1) is they dont go thru the cycle that needs to be done before installing it... seen it first hand people install it without reading instructions you have to go thru a heat cycle with the lc1 before installing it... mine has no problem and seen alot of abuse. i would highly recommend the lc1 but read and follow heat cycle instructions before you install.. on the manual it says if you dont go thru heat cycle it wont work right and will prematurely fail
Is there anything that you can do with the AEM that you can't do with the PLX ?
Is there anything that you can do with the PLX that you can't do with the AEM?
Do these replace the stock O2 sensor? Or are they installed in addition to the stock O2 sensor?
Well I have been seeing a lots of posts from my question. Yet have I seen anyone post the install location and how they ran their wiring. So how about it?
