I've heard it recommended a few times to use the billet timing set from ta but the single version used with the stock tensioner. I'm going this route on my new build. My question is, is this still a recommendation with a roller cam too? I'm not using crazy spring pressures but def heavier than what a ft cam would need. Thoughts? Opinions? Do roller cams require a double roller chain for some reason?
