Block&Parts F/S
278cikiller
3.8 109 block done 30 over block has one sleve all machine work is done From Atchison Racing from London Ontario and is ready to go, comes with six stock rods 30 over piston,arp head studs, front timing chain cover with all hardware and crank sensor, no crank.$500
On this block for i will build the crate for free and will ship bi TNT Overload Trucking.
Red MSD 8.5 used wire set they are number wires $60.00
Used coil and moudle with the mounting plate $125.00
TT chip 5.6 set at 25 pounds of boost with alky $65.00
Used G/N shifter handle in nice shape $50.00
Turbo inlet bell polish alum $40.00
Exchaus housing AR.83 with stock elbo came off a TE-44 turbo $60.00
87 crome grille From a N/A car no cracks or chips $100.00
Crome 1/4 windows in execllet shape $80.00
Electronic Touch Climate Control Unit $75.00
Two sets of stock push rods $40.00 a set
3 Vaccum brake systems comes with correct pedal,no alum.vaccum block.these systems need sand blasted and repainted $100.00 each
Used wiper motor form 87 Regal n/A car $50.00
All parts are plus shipping,Or just phone me at 1-905-419-0704
Block Info
This Block was sleve in number 6 cylinder,all cam bearings are new,all rods were resized and it has speed pro piston all ready put together Drop in your new rod bearings and mains bearings and your crank and away you go.
Why did it require a sleeve? I'm interested in the 8.5 wires as well. Shipping will be to 39042. Thanks Clayton
Red wire set
Pics for the red wire set.
