Blow off valve
87hottness1
Does any one know of a vendor that sells up pipes with blow off valve installed or setup for one thanks
Unless you're running a ton of pressure or going below 10's, they're not needed, so no vendor sells what you're looking for.
If u want one buy one and take it to a welder
When U buy it, ask for the steel flange..{that is, if you are using a stock up.}
