After adding the appropriate amount of oil, start cutting away at the dipstick tube with a tubing cutter. Make sure you fill to the desired amount, (5 qts is enough for most engines) then start the engine and let it fill all the passages and filter, then shut it off and adjust the dipstick tube length.
As a side note, if you have a deep pan and a girdle, you don't NEED to add more oil. There is no real advantage to having more oil in the pan. (unless, of course, the car uses alot of oil
), but there IS an advantage to having the oil far away from the spinning crankshaft.
Something else to note here, is that the RJC pick-up extension for a girdle and deep pan is no where near deep enough for a stock pick-up to reach the bottom of the pan. I just built a new pick-up today for a stroker 4.1 StageI with a RJC girdle and RJC deep pan. The aluminum adaptor placed the pick-up nearly an inch off the bottom of the pan.
I ended up placing the pick-up .275" off the bottom. If the pick up is more than 3/8" off the bottom, it can cavitate under hard acceleration/braking causing a serious problem. In that case, it would be a good idea to add 7 qts of oil to the pan.
