Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
My stock unopened longblock went 117 with a 6131@27 psi. I think 1KWICKSIX has plenty more to go with his current setup if he adds alky.
SignUp Now!Put a cam in it, winters are long and you have the time.206 or 212. my choice is the 212.
it will be easier to get the air into the motor sooner and should use more fuel at lower boost numbers with higher torque ,however,i would never do heads and cam just to run a lower boost number and really never saw any money justified power gains unless the turbo was all in or near it on a stock motor.to give you an example a stock motor can make the same power as a stock motor with a ported head but the boost levels are very different could be up to a 10lb difference as well.26psi on ported heads vs 33psi on a poor flowing stock head.i remember the days when we ran in the 10s on a stock motor,some of us ran 30+psi and a ton of octane others ran 10s on ported this and that,the difference was the money it took to get it done.on pure 94 pump gas and small turbo i would not put that kind on money in the top end personally,now add octane turn it up then add heads and cam and your investment will start to shine.Can anyone tell me what kind of performance gains or losses I can expect to experience . Currently running 94 pump gas @ 18-20lbs Boost.
I loved my GEN 2
ET/MPH and build is in my sig with JB Racing heads. 7 flat all day long at 100 mph on 23 PSI...High/low gear fueling at 800mv...timing 34/26 with Erics 110-112 race chip...easy 1.68 launch.How you guys like your jb heads? Just came across them and am very interested. Thx.
