- May 26, 2001
We had a very similar situation a few months ago, and the thrust bearing in question is shown below.
The engine had 8 easy passes and the filter was full of bearing material. Same trans/converter had been used for over a year.
All the other bearing were like new including the rods, which would have been toast if it was caused by lack of oil.
We did a bore check of the main line and the thrust was a thousand and a half tighter than all the other main bearing bores. The shop that did the work showed me the specs turned in by the tech that did the work. Either he did not tell the truth, or he totally screwed up the assembly and fitment of the thrust cap.
Fortunately, Castillo's repaired the crank, and $2K later the engine ran better than ever!
Your bottom end has NO signs of lack of oil.
I agree on not using the block again, and the crank would really worry me unless it was sent out for check/repair, and even then it would not go in any race engine?
