SignUp Now!bison said:Run it with no wastegate. Disconnect arm or remove spring if external. See where the boost goes. That will be the minimum you can run. I do shakedown runs this way with everything.
The spring in the wastgate will only allow it to push the Puck so far away. It wont allow the same amount of exhaust to be redirected.On my GN we did this and we had it down to 18 psi hooked it back up and adjusted it down but would go no lower than 20psi. Any thoughts why?
ZNix said:The 6266 was a better match for a stroker anyway. I think the 6262 would have been out of breath pretty easily. Can't wait to see some numbers!
Zack
I havent seen anyone on here put a 6262 out of
breath or a 6265/66 for that matter. I don't see anyone easily running either out without a purpose built engine either. Not going to happen with an off the shelf cam and a CR less than 9:1.
Oh. I just heard the 6262 was a 10.8x turbo.. I figured the stroker engine would have no problem running that time.. The 6262 must spool incredibly quick with a stroker... I need to keep learning lol.
ZNix said:Oh. I just heard the 6262 was a 10.8x turbo.. I figured the stroker engine would have no problem running that time.. The 6262 must spool incredibly quick with a stroker... I need to keep learning lol.
Zack
