Do you need an external gate or XFI to run this setup?
Do you have to run CO2 to the WG in order to run this?
Please correct me if my interpretation is off, but this seems like a programmable boost controller that you can set the boost ramp rate, and the target psi for 3 different "stages" ? What dictates where a certain "stage" begins and ends? Rpm?
As for the Pulse feature- does that allow you to put a pre-determined PSI to stage your car at, and keep the WG closed until that target psi is reached, and then you can launch? I know it has transbrake features as well, but since I don't have a TBrake I'm not as interested in those, more the staging info and how that works.
I appreciate any and all info on the subject.
