Oh man, I hope its just the timing and not a blown gasket. I blew both my head gaskets a few months ago and mine was doing the same thing.
wow i didn't know you blew a head gasket that stinks.
Yeah, both of them. I think one was blow for awhile, but never had any problems unless I went out of town and I would have the same problem as Bob. When the other one went, I diffidently noticed it... It would backfire out of the carb just like Bob here, only mine was really bad and hard to keep running. Did a compression test, turns out I was only running on 2 1/2 cylinders The 1/2 was the distributor caps fault:biggrin: Wasn't fun, had to rebuilt the top half of the engine
Like Charlie suggested, have to check the base Ignition timing, being too lean on fuel will cause this too along with burnt valve/seat. I'm going with Ignition timing and fuel delivery problems.i am going by the popping from the carb, (its loud) and the car jerks when this happens, i did check the esc circuit and its functioning per the buick manuals test
sorry to hear that. did you port the heads while they were off.
Yeah, but not much... didn't have time to go all out on them, but I will on the old ones:biggrin: I`m betting its just an timing, ignition or fuel problem too, blown head gaskets where the last thing on my list to check... but sure enough When did you change the fuel filter last? Might also be your pump going out, but that`s another last check thing along with head gaskets, seals...
Very good point about the fuel pump Jase. Rich had a simular issue this past fall and it turned out he needed to rejet the secondaries if I remember right. I found him a high performance pump to try and it didn't fix the problem but it was better than the original design. I don't know if he kept it on there or not though.
Which Q jet Matt?
