hensleyt
- Feb 20, 2008
I removed 3in DP and ported elbow and Installed a TA DP.I have the actuator so loose know I cant believe It even builds boost. It is a standard  actuator, 12-22, (just pulled the invoice) .With the old pipe I was able to adjust boost up and down.and found 18lb to be my max without to much  KR .Vacuum Y is installed correct ,check and double check ,check and double checked boost controller pluming.I know I'm missing something and have did some searching. The real thing that's tripping me up is ,it was 21 lb at my first setting 6 turns on the actuator latter still 21lb .O how do I add my setup at the end of a post?  Tim
