SignUp Now!Mike, you got to see my junk?
Sent from my SM-N930T using Tapatalk
Quick question, does the 3 bolt setup get rid of the twin scroll feature for the EFRs? Which would impact the turbos performance? If so why not use an exhaust housing like the stainless V-band styles that Tial makes instead of the 3-bolt configuration to help with spool, weight, ease of mounting etc?
Love that one wire 02 sensorHere is the "Christmas" update!
The custom Powerstroke IC pipes have been coated, and also the down pipe is installed and high-temp coated.
Plumbing for water and oil have all been completed. The oil drain was a PIA as the pan was removed to weld on a bung for the oil return. I did not feel there was enough gravity "drop" for the oil exiting the turbo with the turbo position I selected.
No air filter yet as I need a specific size to fit behind the headlight.
The engine now runs on the stock ECM with 96# injectors for e-85, and the FAST XFI install is the next step.
The alum inner fenders are under construction, and are a few weeks away.
After I secure a few items, it will be ready for shakedown cruise!
Thanks for your nice comment!
Guess I should post a picture of the whole car which will be a surprise to many on the street!
