turbojimmy
Supporting Member
- May 26, 2001
x2,this plug bypasses all the relays,oil sender,etc.if the pump doesn't energize after applying voltage here,check all wiring leading to fuel pump,if wiring checks out(check plug behind drivers tail lamp/bumper),and also check then fp ground behind the tail lamp (drivers) inside trunk....
sound like ther pump to me......as RC said too.
Actually the wiring is a good point. The ground could have rotted/broken off the lug in the trunk which would prevent the pump from running.
Jim
