Bought more stuff, need to make room otherwise WIFE WILL KILL ME!
How clean are the chrome bumperettes ? If they are nice I will take all three and the new gas pedal to 60101
Steve, Ill get back with u tonight.
I think I have responded to everyone, if missed you, send me a PM. Jeremy
Ill take the billet Tstat outlet.
PM me payment info.
And if your wife kills you will there be an estate sale? (I need more stuff but on a tight budget...):sneaky:
SENSORS, SWITCHES, SOLENOIDS, ELECTRICAL:
1. IAC Valves (4, known good) $20 each
2. Dimmer switches (4, known good) $5 each
3. Headlight Switches (3, known good) $8 each
4. Defrost Switches (2, known good) $8 each
5. Power Seat Switch + chrome bezel ( 6 pin) $15
6. Cruise Control Switch (3, on gas pedal) $2
7. EGR solenoids (4, known good) $10 each
8. Vehicle Speed Sensor (known good) $20
9. Vapor Canister Solenoid (2, known good) $5
10. Chime Box (6 pin) $12
11. Cruise Control Box (2, known good) $12 each
ENGINE, ENGINE BAY:
1. Engine oil and dipstick $40
2. Stock Rockers/shaft (6, all good sets) $5 each
3. oil slingers (6) $5 each
4. Oil Filter Housings (3) $8 each
5. Adjustable Wastegate Actuator (nice) $45
6. Stock Wastegate Actuators (3) $15
7. IC Brackets (either side) $20 each
8. Entire stock IC set up (IC, fan, both brackets, IC shroud) $125
9. HydroBoost Line (Booster to gear box) $10
10. Hot Air TV cable $25
11. Turbo oil feed (2) $10 each
12. Brass Oil feed adapter (4) $10 each
13. Turbo oil drain back tube $35
14. Turbo oil drain back brass fitting $10
15. Valve Cover Vent (passenger side, stock whole set up with turbo bell) $30
16. OE Radiator Caps (3) $5 each
17. Battery Hold Down bracket (2) $10 each
18. Fuel Lines (rail to frame, set) $50
19. Fuel Rail (3) $30 each
20. Stock Fuel pressure Regulator (2) $5 each
21. Tensioner Pulley (2) $8 each
22. Billet T-Stat housing $8
23. Hot Air oil fill tube $15
24. Stock Fuel Pressure Regulator Vaccum hoses (4) $5 each
25. Crank Sensor w/bracket $30
26. New lifters (flat tappet, Speed Pro, 16) $40 set
27. New ACDelco fuel filter $5
28. Factory Air filter Box $30
29. Complete Factory Air Intake (air box, bracket, inlet, hose, elbow, factory clamps) $100
30. ACDelco Fuel Pumps (2, with install kit, one low mile, one new, in AC Box) $15
31. Valve Covers (stock drivers side, 3) $10 each
32. NEW Rod Bearings (Michigan 20 under) $10
INJECTORS:
1. 36# blue tops with ATR chip (NEW) $150
2. Stock low mile Injectors with stock chip, known good (also a few spare stockers, unknown condition) $75
3. 40# Green tops with ATR chip (used, known good) $150
BRAKES:
1. Baer Brakes (NEW, Rear, Ford 9", IronSport) $450
2. Complete Rear Drum Brakes (used for 50 miles, drums and pads fresh, springs, brackets, etc) $50
3. Power Master Pedal $10
4. HydroBoost Line (booster to gear box) $10
5. Complete Power Master (unknown condition, out of 42k mile Car) $150
OTHER, BODY, INTERIOR, CHASSIS:
1. Trans Crossmember $50
2. Rear Carpet inserts (grey, 87 T) $10
3. Chrome Wiper arm set $25
4. Chrome Windsheild Trim (two sides, no top) $10 each
5. Ashtray (back of seat, Nice) $8
6. Swaybar bushings (NEW, Energy Suspension 9.5108G) $15
7. Front Springs (NEW, MOOG 5608) $50
8. 1/4 wheel spacers (2 sets) $5 set
9. 8.5 3:42 Gear Set (used but very nice, 42k mile car) $75
10. Antenna Nut and Spacer (2 sets) $10 each
11. Seat Belt Release Actuators (5) $10 each
12. Dash Surrounds (Grey 85-87, Dark Grey 84, Blue) $20 each
13. New gas pedal $5
14. Chrome Bumperettes (Two front, one rear) $10 each
15. New Cig Lighter (was NOS, no box) $20
16. Turbo Hood Ornament (NICE) $65
17. 3rd Brake Light (Grey, with mount, NICE) $45
18. Underdash Cover (Pass side) $10 each (will trade for a drivers side one)
19. Grey Pull Straps (2) $10 each
F250 99-04 HID Headlight Kit with Harness ----$40
FILTERS, RANDOM:
WIX Oil 51258 $2
Baldwin Oil B9 $2
Puralator Oil L20033 $2
FRAM Oil PH2 $2
FRAM Oil CH9999 (2) $2 each
WIX/Rockhill Fuel 33296 $2[/quote
] Please send me an "engine/engine bay" #12 (turbo oil feed brass fitting) with good threads if you still have a good one left. Please let me know.
Thanks Wayne
Il take the ash tray cigarette lighter and power master for 150 shipped? PayPal email?
Jeremy,
I'll take Power Master Pedal $10
shipping to 14303
LMK shipping charges plz & thx
dave
