Please help me My 87 gn has a problem with the brake system. The motor does not turn on (cycle), and the brake pedal is very hard with the brake light on at all times. I checked the pressure switch connectors (A,B,C) & the Pump connectors (A,B,C,D). "A" from the pressure switch is to be with "D" from the pump. I tested them with a test light but there is no light on. "B" on the pressure switch connector seems to be a little weak. The light does come on. The remaining terminals on the plugs seem to be ok.
Please help!!!
  What do i do now??
  What do i do now??
Mike
  My 87 gn has a problem with the brake system. The motor does not turn on (cycle), and the brake pedal is very hard with the brake light on at all times. I checked the pressure switch connectors (A,B,C) & the Pump connectors (A,B,C,D). "A" from the pressure switch is to be with "D" from the pump. I tested them with a test light but there is no light on. "B" on the pressure switch connector seems to be a little weak. The light does come on. The remaining terminals on the plugs seem to be ok.Please help!!!
  What do i do now??
  What do i do now??
 Mike
 ANYONE. THE FUSES ARE OK, JUST THE PS CONNECTOR TERMINAL A DOES NOT LIGHT UP, B IS A LITTLE WEAK, AND C IS OK. THE PUMP CONNECTOR ON THE OTHER HAND ALL WORK EXCEPT FOR D.
