Apr 8, 2012 #1 K kennygn1 Member Joined May 3, 2006 Messages 63 brand new vacum brake master cylinder and lines, cant get pressure to the back wheel cylinders bench bled no more air. front bled out great but the back ones first crack good squirt then after that barely drips out.
Apr 8, 2012 #2 C charlief1 RIP Charlie! Joined Sep 20, 2007 Messages 23,936 The prop valve has a little tit on one end and it has to be depressed to allow fluid to the back.
Apr 9, 2012 #4 IrvJr Well-Known Member Joined May 28, 2001 Messages 2,547 I used a mity vac and it worked great.
Apr 9, 2012 #5 C charlief1 RIP Charlie! Joined Sep 20, 2007 Messages 23,936 kennygn1 said: so i just have to push that in Click to expand... It has to be held in while bleeding the rears.
