V6UnderPressure
The Artist FKA Scott4DMny
- May 27, 2001
Extender Extreme chip for 55's used for a week. 90 shipped
Stock Map sensor 15.00 shipped
Stock Axles: 1 had two holes drilled to remove backing plate. Filled in with JB weld. 50 each shipped.
Brand New in box AEM UEGO wideband Digital Gauge Black Bezel, black face. 365 shipped here is the info:
AEM’s Wideband UEGO Controller is also available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit! AEM’s Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring! Key Features: Bosch sensor included! 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda Integrated three-digit display reveals AFR or Lambda in real time User-programmable 0-5v analog output included for use with data loggers and ANY engine management system Ideal AFR monitoring tool for carbureted applications and engine dynamometers. Does not oscillate AFR like narrow band sensors.(RS 232)Accurate to 0.1 AFR
1 Aluminum Drum, just turned. 30 shipped.
1LE 36mm hollow front sway bar, needs bushings. 60 shipped.
