mario65
Hot Roddicus Supersonicus
- Dec 29, 2004
I have an alky kit and run 93 octane. My mods are in my sig. I have been running 22 psi for months with what appeared to be no issues and no adjustments to my TT chip. No knock and pure a$$ hauling. I got a boost control bleeder to run above 22psi. The first time I did it I took some timing out and added a little fuel. I saw 25 psi and I as soon as it passed 22psi I got some very light popping almost unnoticeable. I immediately thought to check the plugs. I bought some NGK UR5's and gapped them to 32 and found my old plugs were 42ts AC's with a 40 gap. I absolutely expected the problem to be solved. It didnt fix it. It acts just like it did gapped at 40. I took the fuel out and left the timing retarded some to see if I was overfueling it. It didnt get any better.
My runs are 780-810 on scanmaster.
I am back 22psi running ok. I reset the TT chip back to flat settings.
What would you do?
The coil pack is an accel pack and the coil module is a new autozone piece.
Deep down I hear a voice saying get a real coil module dip****.
Should I just go to a 28 gap and see? Will it hurt drive-ability at that setting?
thanks or all responses.
What would you do?
