turbo nasty
Turbo Dojo / MNTR
- Jul 19, 2001
As far as wear the reluctor can rise up and make contact with cap if bushings, etc in the cam sensor shaft is worn. There will be clear witness marks on the inside. Side note im actually chasing almost the exact same problem at 5800 and I have TA SI heads.No rev limit as I use alky for chemical intercooling on the stock coil pack. The TR6 isnt set up for anything as of now.
What should I look for? cracks? wear?
