87we410877
- Apr 5, 2005
Pulled the rods and pistons out last night to find piece of #6 piston missing. Is this common with these pistons? The car has never run right at higher boost levels and im thinking this has been the problem for a while. I pulled the motor because it leaks alot from the gurdle and started pushing compression into the coolant system.
What would cause this? Just detonation? You can see tons of detonation marks on the piston. I polished #1 piston and it had none at all. Im thinking this has been the problem for a while. What do you think and what should i do? i was thinking of calling diamond and just ordering one piston. Can you do that? Enjoy
