The hard lines from the transmission to the cooler at the front of the car broke, right over top of the crossmember next to the oil pan. I was wondering what my options are as far as replacing them, AN fittings with braided steel, pipe fittings and rubber hose, whats the best choice? If it helps, I have an F-body radiator with an external B & M cooler mounted in front of it, and the radiator cooler and external cooler are mounted in a loop together, per the diagram on gntype.org. Thanks for any advice!
