When does the BS3 NOT stand for Big Stuff?! My saga:
When I itched for a t-top GN, I searched. After 6 months, I found what I thought was a good one. An 86 with mild parts, and only a few of them. New posi, wired Walbro with adjustable regulator, stainless exhaust, K&N filter, boost/knock gauge, new TE44 ball bearing turbo...added a set of 16" GNX wheels. I’m set! A good, basic combo with a solid, unopened motor owned by mature (and experienced) individual. And I’m not new to used cars. I know there will be things. There always is, right? Right.
So when the car arrives (6 weeks after purchase) I take delivery. At the depot, the folks ask me “Where is the flat bed?” Huh? “Ya, that car has no brakes! You can’t drive it.” So I look around under-hood, see it’s out of fluid. Strange. Seller drove it 45+ miles to the depot for drop-off. Well, I topped off the brake fluid and had enough to get my 50+ miles home. Car doesn’t run as well as I would’ve thought, but well enough for me to get home (almost). At 3/8 fuel in the tank, the car stalls and won’t start. Hmm, “Hey Bud, bring me some GAS!” Car fires but runs a little worse. But I fill the tank, (takes 10.6 gals., about right for 3/8) and get home. Must meed some fuel gauge work. No biggy. Closer inspection shows need for a new Power Master.
Well, at least now I know the brakes are ok, though at a price (you know what I mean). Do the other basic things; plugs, tranny service, fuel filter, oil change to Royal Purple with correct filter, install the GNX wheels, and a thorough cleaning and a CD player with fresh speakers. I’m ready for summer fun!! “Commuter Special, coming through!” Shinin’ bright and getting looks and thumbs up everywhere. People wanting to play, I just smile (no need for tickets). Not yet, still to new.
Front vibrates a little and, after a look-see, notice the sad bushings in the front A-ams. I’ll get to those soon enough. Ride to work a few days, happy with myself and new ride, but it still runs rough here and there with bad mileage. Around 15! But it passes CA smog test ok. But it stalls and won’t start 5 or 6 times now. So I set the TPS and IAC after a thorough cleaning. No change. Wires seem ok, but will soon be replaced. Fuel pressure was at 35 psi, so I bump it up to 39-40. Seems the same. Still haven’t goosed it, not yet familiar enough yet.
I start looking closer at the programming in the BS3. Get some help from PTE with the settings, but still not happy. I figure there is a parameter/combination at fault. I’m learning. Play with the maps some (fuel only) and it seems to help overall, until the stall happens. And a program that makes the car happy one day doesn’t mean it’s happy another day. But I keep trying little changes. Make progress, then WHAM! Bad running. Have gone back to original program several times but car has never liked it much. But it’s my base line.
So this week, I go for a longer ride, about 150 miles round trip, for work. Beautiful day. 84*, sunny, tops in the trunk. Lovin’ it! This is what it’s about! Until the stall. Well today, I’ve got laptop, fuel pressure gauge and a few basic tools. Fuel pressure is good, but the BS3 dash is saying very high AF ratio. Like 15.9:1! Uh-oh! So, I fatten the map in all non-boost range by 25%! Also, open the O2 Correction (+ and -) to 25%! Well, it runs again. Cautiously, I motor home, trying to watch the laptop while running. In case something bad changes. It’s seems low on power, but otherwise, not bad. Even the O2 Correction seems kinda happy with only minimal adjustment around 2% - 3% overall.
Next day, it’s running so fat that I think I killed the plugs. I’ll check them this weekend. I dropped the map back towards “normal” but something isn’t right, maybe plugs. I checked all electrical connections and they “seem” to be ok. Cleaned up a little anyway. I’m gonna check the EGR valve (though not in operation) and plugs, looks for vacuum leaks, etc. I’m thinking maybe the O2 sensor may be at fault, but I really don’t know.
So, that’s my story. Any ideas?
TIA, Ed
TIA, Ed
