SignUp Now!Looks like your angles are off a little Al. Can you get a better pic, maybe a little further away?
Secret is in the fittings used! TURBO DRAIN KIT
i dont think you can use a straight fitting on either side.... HAS to be angled... i have made a few but wasn't successful with using them with my combo.... i have a large compressor housing with a stock type WG actuator which gets in the way.... when i can [i am out of town] i will try and post pics...
...my drainback would have worked if 1] my compressor cover was a little smaller or 2] i move to an external gate....
aaron
but it isn't pretty!
had to make a loop in the return hose to prevent kinking,
I used -10 push lok hose,
I'll try to get a pic, but as I said "it ain't pretty"
but it does make install and removal ALOT easier!
To be perfectly honest, braided and stainless braided hose can develope kinks like you are seeing. Typically I recommend going back with a factory style flex tube. Cotton sells a factory replacement as does Nos4gn.
The problem you run into (as you can see in the pictures) using normal hose ends causes the hose to kink and using sharp bend swivel 45* fittings, can cause oil to back up inside the cartridge because the ID of the complete assembly necks down. Some have gotten lucky and not had issues, but I know of a few who have.
The factory flex tubing serves a couple of useful purposes.
- Allows some flex of the line under normal operating conditions.
- Allows the aerated and foamy oil coming out of the turbo to turn back to a liquid state before draining back into the lifter valley.
I have had very good luck using the factory style flex tube on all of my Turbo Buicks. Never had any good results with braided lines, due to how cramped an area we're working with and kinking issue.
Just my O2's worth.
Patrick
