I just installed the flynbye rear bracket and everything lined up great after a bit of grinding the flange for backer plate. The issue when bolted all together the rotor hits the inside of the brake bracket.
It needs .075" more clearance, thinking about machining the bracket .075" more to shift it back and to be in center of rotor.
I am posting pics of the car lowered and the front brakes that were done last month.
Just seeing if anyone else had this problem with the caliper bracket, looks like I wont need to relocate the strut either but wont know till I get her on the ground and weight on the rear axle.
Any advise or concern I would appreciate.
