SignUp Now!T-CHRGD said:On the Baer website it shows a SS4+ with a 13" rotor and parking brake. Check with Scot W. to see if it's available for the GN.
Paul, which calipers are you using? I have the stock C5 on mine. I have a 9" rear so things are a little different but are you planning to run 15" rims at all at the track? I had a hard time finding a kit for the 9" that would match big brakes up front and still clear my 15" wheels.
If you've got an 8.5" rear I can help you out on the 9" ferd rear Paul. I'm in Hillsboro which isn't that far from Austin if you feel like driving a little.Have you checked out the track/club in Cresson outside of DFW for road course driving?
One of my customers is a member and I still need to get with him and go up there.Charlie,
Are you talking about motorsport ranch? If so I have been there, its was probably 12 years ago though. I remember it being real nice, they even had a skidpad area. I know exactly where Hillsboro is, probably a good hour and 45 minute drive for me, not too bad. I'll PM you. Thanks
I've been wanting to do this since I first put the wheels on in Feb 2011 and finally got it done. The old brakes just didn't do the Rushforth wheels justice. Any ways, this was a real simple installation bolt on swap thanks to Mark at SC&C and Tobin at KORE3. I used Mark's upper control arms to work with the ATS spindles that I simply bolted the brakes too. This setup supposedly pushes the track out about .25" so if anyone wants to do it, keep this in mind. Now I need to find a good solution for the rears! Anyone have any LS1 rears laying around? Also, KNSbrakes is almost giving these DBA rotors away, check them out, I got these for the same price as the OE stock junk rotors View attachment 158831View attachment 158832
The ATS spindles use the factory c5/c6 corvette hubs. Contact Tobin at Kore , he can help you out with whatever parts you need for doing a gm big brake conversion.I am doing the same conversion, but using blazer spindles, what hubs did you use if you dont mind me asking.
Thank you so much for the response Tobin had been a great help, one quick question and perhaps noob question, by ats spindles do you mean ats cadillac?The ATS spindles use the factory c5/c6 corvette hubs. Contact Tobin at Kore , he can help you out with whatever parts you need for doing a gm big brake conversion.
Paul
Thankyou so much for the link and information! Hopefully Ill do the install soon, still missing one caliper..,no not the cadillac ATS. I guess they don't call them ATS spindles anymore, now they call them AFX... since speedtech bought them out. http://www.speedtechperformance.com...ct_id=221/category_id=96/mode=prod/prd221.htm
Im doing c6 calipers, what are you going with?There will be no finding those ATS spindles in the junk yard, lol. Sooo I will be doing the same as Geezy... using my Blazer spindles, and buying the abutment brackets, and calipers from KORE.
