TURBOELKY
- Jun 27, 2005
Hello. I’ve decided it’s time down downsize my collection of cars and up for sale is my 1987 Rosewood Limited. I purchased this car from the original owner, and have all the history of this car. It was bought near by at Keyes of Van nuys, and has never lived anywhere but the city I’m in now. I chased this car around for 13 years and finally had the opertunity to own it.
Now she’s spruced up mechanically, and unfortunately, needs a new home. I’ll I’ve the most honest and up front description of this car possible, and there is nothing to hide being it is 100% documented! Everything from the first oil change to the rebuilt radio!
I’ll start with the not so desirable:
The car has been re painted once, it was a cheap $600 dollar paint job. She’s photogenic but could use a repaint.
At one point, the car had a minor fender bender where the header panel, and hood were replaced which is all documented. They re painted the front and and the color is not 100% to the rest of the car.
Interior is faded, it did sit in the sun for some time, as well as provided the owners years of enjoyment, and shows its ware. The limited carpet however is still in good shape and cleaned up well.
I’ve changed the trans pan gasket as well as tailshaft seal, but seems to have a leak at the front pump gasket and I don’t care to take the trans out at this time.
Mileage on the documents stopped at 136k, so I cannot say exactly what time try mileage is, I would imagine it’s close to 200k? But can’t guarantee it.
THE GOOD!!!
If you’ve made it through the bad, you obviously still show interest and I can tell you this...the car runs EXCELLENT.
The following work has been done:
New BFG tires all 4
AC Delco steering components
Moog ball joints
Energy bushings up front
Replaced steering box
Replaced front brakes
Hydroboost brake upgrade
Water pump and hoses
Heater valve
AC BLOWS COLD!!
O2 sensor
Rear main seal (original was still dry!)
Pan gasket
Trans pan gasket, filter and fluid
Shifts perfect
Tailshaft seal
Flushed brakes
Spoolfool rear filler
All seat belts replaced with mint belts
Rear package tray & 3rd light replaced
A pillar/B pillar trim
New bosh battery
Ignition and coil
Plugs and wires
Aeromotive In tank pump w. Hot wire
Fuel filter
42lb injectors w/turbotweak chip
RJC power plate
Stock MAF sensor
Serpentine belt
Rear end service
Heater core hoses
Upper roof rail seals
Outer dew sweeps
Power steering pump
I’m sure the list goes on but that’s what I can think of at the moment. This car runs better than most low mile cars here locally and I don’t hesitate to jump in it and GO! Very dependable and very fun to drive. It spent the last several years of its life stuck not able to go past 1/4 throttle because a shop put a vacuum source into the plenum, and it jammed up the throttle. I have picture proof of that. This thing does NOT puff any smoke at all on startup, no funny noises, it just does what it’s supposed to do!
Looking to get a fair price for a California ZERO RUST DOCUMENTED LIMITED.
$12,000 as is. Shipping available, test drives available with cash in hand only. No trades please unless it’s performance parts I may need. Thank you!
Jeremy 818 233 4211
THE GOOD!!!
New BFG tires all 4
Moog ball joints
Heater valve
AC BLOWS COLD!!
O2 sensor
Pan gasket
Shifts perfect
Tailshaft seal
Flushed brakes
New bosh battery
Ignition and coil
Plugs and wires
Fuel filter
RJC power plate
Stock MAF sensor
Serpentine belt
Rear end service
Heater core hoses
Outer dew sweeps
Power steering pump
Jeremy 818 233 4211
