Had to have block machined due to cam thrust face wearing block. I can only find a SBC wear plate/shim to make up for block machining (.030" thick). Problem is, Buick cam journal is about .100" smaller than SBC making wear plate very loose (about .100" on diameter) vs. cam bearing journal.
Is this acceptable, OK to use SBC wear plate?
Thanks in advance for your response.
