Firstly, where to get the cam bolt that would have an integral roller bearing on the bolt head. I had this when I aquired the engine but broke it and substituted to a normal one. It is clearly rubbing the front cover and I cant shim it less. I'm using racepumps fuel pump, and the tolerance between the pushrod and chain is small. So in order not to let the cam walk forward, I would need to shim it .001 but I would feel better if that bolt head that contacts the front cover would have a torrington bearing.
Secondly, what makes the timing chain go "stiff". The links are not free to pivot as they should. The chain has 5 passes on it.
I had the fuel pump interference issue before and the chain grinded the pushrod, I dremeled out the pushrod sleeve, replaced chain and now with new chain same issue, mut it has not rubbed, there are no marks on the chain or the pushrod sleeve. But still, the chain has gone "stiff".
Thanks.
Thanks.
