Cam button
Brad_H
Does it matter which cam button I get off of gbodyparts
Or
Does TA provide one with the #ta v1522b billet steel timing gear set with single style silent chain and tensioner
Just Getting a parts list ready For a new timing gear set And a neoprene rear main seal
Depends on what type of cam you run. Flat tappet can use the spring roller button or the shim style. Roller cams should use the shim style button.
Go with the spring style roller cam button. You'll prolly need to flatten the thrust surface on the front cover, but that's fairly simple to do.
