m233roller
Banned
- Jan 25, 2002
Has anyone had a cam ( this is a 210-215 roller cam) eat into the front of your block? If so what was your fix and why are they doing it in the first place?? Thanks Mike
SignUp Now!We all have to be continually aware when using ANY aftermarket part, it may not fit like a stock part. Then you add many a/m parts, all of which have been made by different companies and countries, can all have different tolerances and fitment from stock parts.
This is why it is important and imperative to check and re-check when assembling a complex unit like a performance engine.
BobbyBuick said:Wouldnt a high volume pump cause the cam sensor to push the cam rearward with more force due to the bigger gears and stronger spring .
MY FRIEND JAY ALWAYS USED A TORRINGTON - CAM BUTTONNick, the only reason I say what I did is from my observation of a 100% bone stock from GM 109 engine that was in my dads car. It had about 100,000 miles on it and the surface of the block was chewed up some. Not bad but I wouldn't have put a factory style cam on it. Only a Torrington bearing setup was feasible. Now I know that is only one but I can see it happening more often.
Seems like about 1 in 10 aftermarket cams will wear the thrust in the block. Too tight or imperfect thrust surface on cam can do it. I always deburr the thrust surface on the cam as well as sand the thrust surface smooth. I also check the cam for straightness and straighten as needed. How deep is the wear? Most billet cams use a torrington thrust bearing and an adjustable thrust bumper so wear of this type does not happen. Ive machined a few billet cams to accept these thrust setups when they cam with bronze washers originally.Has anyone had a cam ( this is a 210-215 roller cam) eat into the front of your block? If so what was your fix and why are they doing it in the first place?? Thanks Mike
m233roller said:Bison,
As I stated I haven't tore it down yet but I'm next to positive that's whats going on. Is 0.006 end play to tight? I didn't think so ? I did not deburr the thrust surface as it looked and felt very smooth. Cam was not checked for straightness. Yea I ran a Weber billet cam with the torrington set up and ran it for 7 years, NO problem, all looked new when I took it out. Thanks Mike
m233roller said:Thanks Brian and that's exactly what I was thinking about doing when I get this thing apart. I know that's whats going on and if the front of the block is to ground up I'm taking it to my machinists (Kevin) and have him machine a pocket in it for a torrington bearing. What do you think of that? Thanks
PS. I'm also going to get alittle more end play in the new set up, like .008 to .010
