Cam Help
forcfed
Hey guys does anyone have reccomendations on a good cam for my current buildup??
Here it is....
Block punched .035 over,Champion ported iron heads,T&D roller rocker assemblies(1.65),champion ported intake,billet caps,speedpro rings,bearings,accufab 70mm tb and dog house,havent chosen injectors,chip,and cam yet....this is what i need help on.
I don't care if it is a lopey idle.....I want power.
Thanks for any help.
Doug
HI !
COMP CAM 212/206 from Dave Weber Weber Racing
it is a custom grind from Dave Weber
you can check on Harper`s racing site
Orlando`s setup
lunati 210 205 look near the same
it is only my opinion
hope it help you
Claude quebec city
pclaude@labrie.qc.ca
p.s. excuse my english
GN 87, 93 ATR STREET CHIP, K & N AIR FILTER AND 340 WALBRO FUEL PUMP 13.45 @ 105 17 PSI 91 OCTANE AND XYLENE
Smaller cams typically have smaller power bands. You need to state how fast you want to go, not just what the other parts are.
People go fast with the 206/206, but people often go faster with bigger cams with their broader power band.
Rollers have the largest power band of any cam for these cars.
I would like to run in the 10's if possible....I heard the rollers were the way to go...any suggestions on the roller units?
Thanks:confused:
Here it is....
Doug
i've never seen a block bored .035" over??? lots of guys going fast in the 10's with mild 206/206 or 212/212 cams...if i was to do a cam right now i would do a 212/212 CC roller...great cam and really mild for street use...
The engine block I have gotten was already bored .030 over...we needed to clean up the cylinder walls so therefore we went over another.005.
I had je make me a set of custom made pistons(with 3 extra of course....just in case)to work.
Thank you for all the input and I think I am going to go with the comp cams roller setup.
BTW does anyone know who makes a nice aluminum oil pan for our cars???
Doug
