Do all turbo 3.8's have the grove in the front journal?? Can you do without it if you use the hardened brngs with the grove behind the cam bearing? Also what is the difference in the 84 to 87 head bolts? I see a different listing for the different years.. my 84 has a 79 to 83 block appearantly with the 4885 heads from the later model..discovered all this after I bought it and was not what the seller said it was.. oh well... thanks.. mike
