hi , i have a medium problem, today i run a car and the cam sensor gear strip........recently i change the oil pump cover for a new one (jobber from ebay) becose i can't find i o.e.... it is possible the new cover have a bad alignement(for the cam sensor).......i have a roller cam and my oil presure was 40 pound idle hot ! before i strip the gear ! now is zero oil presure lolllll.....i remove the front cover ,check the oil pump....no problem whit the oil pump ! the cam sprocket is a little bit use and i have a 1/4in teeth broke!what is the best to do ! change the cam whit the can sensor and drop the oil presure at 20 idle hot !
thanks bob
thanks bob
