Thanks for the replies guys. I'm going to pull the converter this weekend and send it out. Hopefully that takes care of the majority of the problem.
Id check the springs too asap. Measure them on a spring tester and verify installed height. If you have them in there at less than 105-110psi on the seat at that boost pressure you are leaving performance on the table.
