buickfever
Yeah, It'll smoke ur Hemi
- Aug 2, 2009
I see lots of threads addressing roller camshaft endplay (not billet), and lots of good advise for methods of getting it right. Most will probably agree that after 2 attempts, you should start over with a new gasket. Here's my question...has anyone tried using something like blue painters tape to simulate a gasket while fitting, then switch to the real deal once youre in the ballpark? I would then re-check to make sure, but i would think the tape would have a similar thickness and crush qualities as a little front cover gasket.
Also, I had my block machined for the torrington bearing, Does anyone recommend running the endplay on the tight side with this, (like .002) or follow comp cam's recommendations?
One more...I see lots of people stick their dial indicator in an oil drain hole to get their readings. This would keep the dial indicator at an obvious angle. Do I need to compensate for false readings. I know there are better methods, but I'm trying to put it together, not take something else apart.
