After reading the post on 6262 turbo times and combinations, I would like to know what effect changing the exhaust lobe duration has on a turbo charged engine? ........... What effect would changing to a 210/206 or 210/214 dual pattern cam have if everything stayed the same? Just looking for the theory behind so many somewhat similar cam grind..............
The internet provides us with a wealth of tech information as well as lots of advertising hype - good and not so good.
Questions like your's can be discussed with opinions, but since many other factors in a build can affect the final result, it will generate many opinions, but the "proof" can only be obtained when subjected to real world use.
One major omission here is that actual use and operating conditions are not given, are you looking for maximum performance for your build for street or track operation?
Cam manufacturers and vendors would like us to change cams every time we make a change to our build because that is their business. Do their latest and greatest cam profiles give us any more performance unless we are taking our build to the limit, probably not?
Maybe seeing many stock cams running into the 10's with good add-on parts has given me the opinion that just changing a cam that is working well in a given engine combination is not going to make much more power, if any.
When we get into expensive competition builds, we want the best match possible working under the rule limitations to obtain the most HP possible. To find the best choice then requires dyno and track testing, as well as knowledge of prior builds of ours, and others that have gone down the same road.
With all that said, if you feel a certain cam is what you want, go for it as I do not think you could make a bad choice!
