SignUp Now!I pulled it off with no problem - putting it back on - not easy! I can't get the o-ring and everything back in - even using the 2 mounting screws to help press it in. What is the trick to this? It looks like the o-ring and the plastic ring behind it should go into the fuel rail.
Disconnect the battery first.
My Accufab regulator does not use the plastic ring, is your stock? Loosely make up the threaded fitting first, push in the regulator as far as you can by hand, then do the bolts, then finish tightening the fitting.
Hope you did like Rick said and disconnected the battery or you will look like Fire Marshal Bill!![]()
Start the treads in the return line to the reg then bolt it to the rail sometimes it works like a charm others it a b***h lol easy project though
You my friend did not follow our instructions. Always have a spare oring handy.
Mine is a stock look alike adj. regulator...
