dr_frankenstein
Mad Scientist
- Mar 17, 2008
Go on...... Cstravo you have our ears.
SignUp Now!On one of mine it took 28-29psi to make 700whp. With a smaller displacement engine is expect more hp though at higher pressure ratios.At what rpm/boost was that achieved ???
What mods were done to the engine/heads ???
Just asking because maybe I'll swith over to a toyota 3.4 in the future.![]()
Bison: If he's on turbobuick, ask him to start a thread...150# seat force is the highest l've seen for the 3800.
Any good engineer should be able to quantify his statement...never mind qualify. Soft HOW? Are you just looking at advertised vs 0.050" vs 0.200" duration? Are you talking about acceleration, or jerk?
I must be a bad engineer and wasted money on these 300+lb on the seat springs.![]()
Speaking from personal experience, I been from 180# to 270# and can't quantify any gains but I also been pushing it harder as I been stepping up the hardware so its hard to say what is correct without any information on the combination.
Allan G.
What you guys do with those 3 bolt housings is amazing. I'm sure back pressure is high and as a result the proper cam timing is that much more important.Sarcasm doesn't come across right, I don't follow the low spring pressure on a turbo car theory. I've got all the right valve train to go with the monster springs. As long as your valvetrain can handle it, I see no reason to not go too high on spring pressure.
I've had issues with valve spring pressure being too low before on a turbo car and it's quite obvious when it's too low (power drops off like a rock). I don't know all the details on my cam and springs, but I trust Chris Hogeland put the right stuff in it. I do know the cam is aggressive. Also remember, I'm running a 277" motor and a .85 A/R 3 bolt turbine housing with a little 68mm turbine. Next time my headers come off I'm putting a bung in put log backpresure. I expect it's pretty high.
I was interested in your suggestion about the cam lobes and thought I would at least look into it. Now I know why I never gave these a second look. There is an immediate problem with using the EHI/EHX profiles as you suggest. Anyone care to guess ? Here is a hint. This is quoted directly from the comp catalog.don't l feel like an a$$. l didn't read the whole thread last year, when l posted, and not until just now :/ A low 9 second V6 street car is surprisingly doable.
btw, those ramp rates are VERY quick. How is valvetrain deflection with those 240# springs? (i.e. lift at the valve). Comp has some VERY nice LSX cams EHI/EHX that will rev to 8000 and .800" lift with 150# conical springs and short travel hydraulic lifters. Perhaps they can grind you a gentle cam for the Stage II. Hollow intake valves will help greatly.
The EHI (intake) and EHX (exhaust) Series are higher ratio versions of the DHI and DHX hybrid hydraulic/solid roller designs.
These are intended for race applications that may see some street use or for other special applications with their primary emphasis
on performance without compromise for noise concerns. 27 MAI intake and 30 MAI exhaust. 2.036" Journal MINIMUM.
