83turbomon
Starvin Like Marvin...
 - Aug 9, 2009
can you?
SignUp Now!can you?
......... With no flow control your fluid would circulate through the cooling system at a much higher rate. This means that heat soak or the ability of the fluid to transfer thermal energy will be reduced. This will actually lead to higher combustion chamber temperatures and less heat transferred from the coolant at the radiator. It will make your cooling system much more ineficient...
Our experience on T-R's has not shown this to be a problem, but just the reverse.
On race cars we certainly do not run antifreeze or thermostats. The higher flow rate will help cool critical areas like the heads, especially around the exhaust valves. Experiments with a protype high flow water pump from TA Performance also provided data to verify more cooling/flow to the heads gave a slight increase in HP.
It is also easier to maintain a consistent water/engine temp between rounds.
For many street GN's we have run them w/o a t'stat for many years and have found no problems. Granted, our freezing temps are very rare here.
Our day-to-day cooling situation is most likely more critical here than any metro area in the country, and we have NEVER found the water circulates or flows too fast through the radiator.
At 115 degrees, it WILL run cooler w/o a thermostat. :biggrin:
I do agree, if you are in an area of the country where the coolant temp will not reach a normal operating range w/o a t'stat, that is not good, and one should be used.
Like many questions posed here on the board, it is so broad and not defined so a specific answer is impossible without many qualifying criteria. :smile:
How can running no stat hurt MPG's? It usually gets around 98 in the summer here. I'd love to pull the stat but don't want to screw my drivability or mpg's. Thanks.
